Pressure washer
  • Pressure washer
    Just bought a 3000# unit with CAT pump and noticed that without the engine running and the house water on that there is a stream of water through the wand nozzle whether the trigger is pulled or not. When the wand is pressurized (engine running) it stops and remains stopped until the engine is stopped and the wand is depressurized then it flows again. I've had several pressure washers in the past and have never seen this before, a flow without the trigger being depressed. Is this normal with this unit? It's not much of a bother but I'm wondering if there is a defect in the wand.
    Re: Pressure washer
    It shouldn't do that. I would call Ridgid for a new gun.
    Ern
      Re: Pressure washer
      I agree. Please call customer service or PM me your contact info and I'll pass it on.
      1 866 539 1710
        Re: Pressure washer
        I have one from Northern and it does the same thing,
        I have had it for about 15+ years now,
        but it will flow a small amount of water through it sysem when it is not running.
        and it has worked well now all those years.
