18v lithium battery question
  • 18v lithium battery question
    I have the older nickle cad battery set i think it is anyways i would have to go look but it is the older set and was wondering if the new lithium 18v batteries will work on this set as i need 2 new batteries, If they will will they charge on the old charger as well?
    Re: 18v lithium battery question
    lithium-ion 18v batteries will work on all 18v or 18/24max select tools
    You do need to buy the correct battery charger for the Lithium-ion batteries.
    The dual charger will not charge lithium-ion batteries.
    The older single charger unless it has the lithium-ion decal will not charge lithium-ion batteries.
    If you try charging lithium-ion batteries on the incorrect charger you will damage the batteries and probably the charger too.
    Cactus Man
      thank you very much for the info sir.
