TP1300 thickness paler
  • TP1300 thickness paler
    Help! I am having trouble with the boards stoping in the planer. It sometimes is so tight that I can hardly pull the boards through from the back side. Dept of cut is about 1/4 of turn each new cut. Any help?
    Kent
    Re: TP1300 thickness paler
    Clean the rollers and (re)wax the table. Dull knives can also cause this.
      What do I clean the rollers with?
      Thanks Kent
        I use mineral spirits.
          I have the same planer, I've had alot of problems with it, broken sprockets,drive chain, and now the casing that hold the drive chain is broke. I up graded to the Ridgid planer. With the 1300 you can only take a 1/32 at a time.
          Brian
            Denatured alcohol also cleans up the rollers easily.
            Go
