Jp0600
  • Jp0600
    would you purchase a JP0600 Jointer for $175?
    I need to look at it, from pictures it appears to be in good shape.
    has been described as "unused for 5+ years only needs a light tune-up to be perfect".
    I believe I've read you need a jig for setting the blades on it, is this true? How bad is a blade change?
    Anything to look for?
    Thanks,
    TxMoose
    Re: Jp0600
    You pretty much need a jig of some form or another to set the knives on most jointers so I wouldn't let that point influence you either way. Overall the Ridgid jointer over the years has received very positive reviews so $175 would be an average price for one in good shape. At that price both buyer and seller should walk away happy.
    ------- Henry Ford
      Re: Jp0600
      TxMoose...its one of the best tools i own. is the one you are purchasing gray in color or the newer orange and black?
        Re: Jp0600
        Its the gray one.
        Thanks for the input guys.
        TxMoose
          Re: Jp0600
          Ok so I picked it up. Its in very good shape, a bit o wax on the bed and checking the beds it should be good to go. Now how about a mobile base anyone have any suggestions.
          Thanks
          TxMoose
            Re: Jp0600
            i have this one:
            http://www.finewoodworking.com/ToolG...t.aspx?id=5822
            the review is dead on. good accessory with considerable flexibilty. once set up, it handles the ridgid jointer effortlessly and easily. if i remember right, it's about $50 from general international. now that i've decided to ditch the lousy htc 1000 base that came with my 18" jet bandsaw (350lbs), i'll be getting another 50-025, when the mobile wheels are retracted, the base is very stable. HTH. BTW, that gray model is guaranteed for life. if you check the guaranty that was in effect when it was built, the guaranty attaches to the tool, not the owner. no need to register it for the LSA as the serial number identifies it for service purposes.
              Re: Jp0600
              Thanks for the help
              TxMoose
