Need Motor for wd12000 wet dry vac
  • Need Motor for wd12000 wet dry vac
    Hello,
    Was working with the kids, shop vac left outside the garage and got rained on.
    Motor is rusty now and its making a racket that is getting worse (and while it is likely the expected result of such neglect) I still need to get it fixed.
    The parts diagram from rigid does not list a part number for the vac motor, it is missing entirely from the pdf. Is this not something that can be replaced?
    David
    Re: Need Motor for wd12000 wet dry vac
    No one any help here?
    David
      Probably a case of the repair part costing nearly as much as a brand new vac. Sorry I don't have a better answer for you but maybe a call to a Ridgid Service Center will get you more specific details.
      ------- Henry Ford
        I have replaced the vac motors using vac motors from w.w. grangers, jsut have to look and visulaly match the unit, and by the specifications,
        http://www.grainger.com/Grainger/wwg...or&N=0&sst=All
        but the motors are not cheap it may just be as good to look for a replacement on sale.
        I know there was some one else some time ago looking for vac fan replacement and had some problems, I do not know if they ever got it from Ridgid or not.
        you could take to motor shop and see if the bearings are replaceable, or if they can find a replacement,
          Thanks so much for the info folks. Not exactly what i wanted to hear, but maybe i expected as such. Didnt think of granger.
          The issue is that this vac seems to have a separate path for the exhaust vs the air to cool the motor. The new ones seem to pass the air through it.
          Maybe I am wrong, guess will be buying a new one.
          Thanks again,
          David
