R2600 speed control
  • R2600 speed control
    Does anyone have any experience with the speed flluctuating on this tool? It stays steady when I press down on the speed control wheel but otherwise fades in and out. I'd appreciate any ideas on whether it's a part or the speed control circuit itself.
    Re: R2600 speed control
    My 2600 is steady, in that when it's in use I see no difference in the set speed. If it is changing speed as you press the actual speed dial, it sounds like you've got a loose connection on the circuit board.
