MS1250 Rigid 12" Compound Miter Saw
  • MS1250 Rigid 12" Compound Miter Saw
    I have the above named saw. I understand that it is NOT suitable for adding a laser to it. If that has changed, please advise.
    I am interested in adding an "extension table" and fence to this saw. I see two large holes under the (approximate) 5" extension table that came with the saw. Is there an attachment of some sort, perhaps with tubes (pipes) that can be added?
    I want to be able to place a stop anywhere from 2" to 36" from the blade for quick repetitive and accurate cuts.
    Suggestions, please..........
    You may e-mail me privately if you choose to. Please use Compound Miter Saw as the subject if you e-mail me.
    Thanks
    I can not help you with your issue but am wondering if you can tell me what I have to do to change the blade?
    There are a number of ways to fabricate extension tables for a miter saw.
    Norman Abrams from the Yankee workshop did a project.
    Wood Workers source did a project.
    U-Tube has a number of videos showing various extension tables.
    Personally I have a cart where the wings [extensions] fold up and down.
    your specific design will be delineated by the space you have for your miter saw and
    if you want a permanent or portable system.
    Cactus Man
