PALs for 3660
  • PALs for 3660
    Can someone please tell me what they are?
    Re: PALs for 3660
    Do you mean "pawls"... I know there's a big fan club for the saw, and I guess one could say that the 3650 and 3660 series has lots of "pals" , I think you're talking about the "pawls".
    "Pawls" (at least that's what I known them as) are the anti kick-back teeth that sit near the rear of the blade guard where they ride on the work piece as it passes through the saw blade. (On some saws, it is a integral part of the Blade Guard/Riving Knife [or Splitter] Assembly.) They are usually spring loaded, cut sheet-steel teeth that point in the direction of travel (away from the saw blade and operator, toward the outfeed side of the table.
    While they normally ride on top of the stock, the angle, sharpness, and spring force of the mechanism, will immediately bite into the stock, if any attempt is made to reverse it's direction. The idea is that they will bite into the stock and keep the saw blade from kicking it back at the operator, in the event that there is any binding with the rotating blade.
    Pawls should always be kept clean and sharp to ensure that they prevent such kickback. Regardless of the table saw design, blade speed, or horsepower, the force of a kickback can be of such power as to break bones, seriously lacerate, or even kill an operator. A few years ago, someone posted a picture of a kickback that had missed the operator, but had travel across the shop and logged itself into a door panel, like a spear! So, anti-kickback "pawls" are a very important safety feature.
    I hope this helps,
      Re: PALs for 3660
      I think he means the alignment PALs that are installed
      under the table to aide with blade alignment.
      http://www.in-lineindustries.com/saw_pals.html
        Re: PALs for 3660
        That's it. Thanks!!
          Re: PALs for 3660
          Doesn't the 3660 have a built in system that is similar to the aftermarket PAL's System which means that you don't need the aftermarket one? I know my 3612 does so I'm assuming the 3650 and the 3660 do also.
            Re: PALs for 3660
            Man, I love this forum.... everyday I learn something new.
            Obviously I didn't have a clue
            Thanks Bob D,
              Re: PALs for 3660
              Yep...the 3650/3660 already have an alignment adjustment...no need for PALS.
              Here's what they look like though:
