soap detergent feeding problem 3300 psi 3.0 gpm pressure washer
  • soap detergent feeding problem 3300 psi 3.0 gpm pressure washer
    just bought for my business and I was wondering what activates the feed from the detergent bottle to use the soap. My goal is to be able to spray soap first, and then go directly to using water to rinse. But not sure what activates the detergent to come in the line, is it just the soap blaster nozzle that controls when to draw the detergent, and does it come out in a low pressure spray? my other theory would be pulling the injection hose from the nipple where the other water inlets and outlet is would stop drawing water or is it simpler than i think.
    Thanks
    Semper Fi
    Re: soap detergent feeding problem 3300 psi 3.0 gpm pressure washer
    Not sure about your specific model, but most are designed to only draw liquid when using the large orifice nozzle(black). Once you switch to the pressure nozzles the tube won't draw. Make sure the detergent is not too thick, you may have to dilute it a bit.
      I use a pump sprayer and apply cleaner and give it a few minutes to work before following with the pressure washer. I was initially bummed that I could not do it in one pass with my pressure washer injecting the cleaner automatically but I think the results are better doing it separately. The pressure washer soap can be applied to a much higher concentration then blasted away and diluted with the pressure washer.
      I too do not like extension wands. I will go to a ladder or some other method to get me higher before putting on the extension wand.
      Seed up with best pressure washer detergent soap. Reviews help you to decide to chose best power washer detergent chemicals soaps.
