nicad batteries
  • nicad batteries
    I have some nicad max 14.4 (?) volt batteries. The fit into my cordless equipment that came with 18 volt lithium batteries. Is there any problem in using these batteries?
    Re: nicad batteries
    no. your tool just won't perform quite as well as it does with the higher voltage batteries, but in a pinch.............
      Re: nicad batteries
      I'm not an electrical expert, however I believe running a low voltage battery in a motor designed for higher voltage will cause the motor to run hotter and possibly damage it. I agree with Finer.....Ray
