Pressure washer 3300 PSI
  • Pressure washer 3300 PSI
    I cannot for the life of me get the noozles off the wand that was supplied. Any help
    Re: Pressure washer 3300 PSI
    There should be a spring loaded collar you either push/pull to release the tips. It can also be necessary to push slightly on the tip while trying to release the collar spring pressure. Later!
      Mine do this to me--often. Even after I bought a new set. "shadow" is correct in his statement. I also put a drop of oil into the female part--often, since this started. I also clean the male end of the tips with steel wool to keep them smooth. I hope this helps, David
