Pressure Washer Problem - RD80903
  • Pressure Washer Problem - RD80903
    I have a rigid power washer. Whenever I have the soap nozzle on and try to use the soap dispenser the syphon hose blows off the brass tip. It on occasion also blows of plastic tip where you turn for the option for soap/tank/bottle.
    Any suggestions on what is causing this problem?
    Re: Pressure Washer Problem - RD80903
    Trim off the tube about 1/2 inch from the end (it has become stretched). Reinstall the tube and secure with a small hose clamp or plastic zip tie. You can also replace it with thicker tubing w/ the same inside diameter. Just bring a piece of the old tubing w/ you to HD to compare sizes. HD has plastic tubing in the plumbing section. They even have the reinforced plastic tubing.
    Hope that helps,
    Ern
