Threading Alum Conduit
  • Threading Alum Conduit
    Do you need special dies for alum conduit
    Re: Threading Alum Conduit
    are you threading a taper or straight electrical threads?
    i would think the oil is more critical and new sharp high speed dies.
      Perhaps the reply should be a question...
      Why do you want/need to thread aluminum electrical conduit?
      The conduit is "thin" compared to plumbing galvanized or black pipe!
      Cactus Man
        actually they make sch 40 aluminum conduit in the larger sizes. i know it was a weight factor. not sure if grounding was also a bonus.
          Tapered Elec Treads with brand new dies. Dies are cutting too deep
            what die head are you using?
            dies are adjustable and the easiest way to pre adjust them is to take a factory nipple and snug up the dies while you thread them onto the nipple. once fully on, tighten down the screw/ screws.
            what size and what die/ machine? hand or electric?
            are the threads cutting good?
              Yes they do make rigid aluminum conduit that is practically sch 40. We used miles of this stuff in a textile mill to prevent sparking of hit by a ferrous object. As far as the threads being cut too deep, I think this would/should be a matter of die adjustment or maybe checking the dies to assure you have the correct ones. David
