3000 psi pressure washer pull cord problem
  • 3000 psi pressure washer pull cord problem
    Just about every time I start my washer with the pull cord, the cord retracts and gets locked in position so I can't pull it any more the next time I use it. I have tried letting it retract freely and with under tension and it still seems to feed back improperly. Any advice? When I unbolt it and manually pull it out and retract it seems to work good the next time, then gets jammed up again. This washer has only been used for less than 5 times but I'm getting really frustrated having to mess with the cord. Thanks
