Pressure washer pump
  • Pressure washer pump
    when I start the pressure washer the pump will build up pressure and stall the engine. I took the pump apart and there is no blockage or broken parts, After I installed the pump I had good water flow without the engine started, when the engine started same results.....Help
    Re: Pressure washer pump
    The unloader is stuck or binding.
    Which pump? Which p/w?
    If it's still under warranty you need to hope that there's no evidence that you've attempted repairing it yourself.
      I just purchased the ridgid preasure washer and I have the same problem with the pump stalling.
        It is sad that a product right out of the box is crap. Later!
          Ridgid currently has five different models of pressure washers. It might be helpful to narrow it down a bit if you're seeking assistance.
          EDIT: five MAJOR models, with a few minor variations.
            I challenge you to point out ANY piece of power equipment made by ANY vendor that is immune to the occasional DOA.
