I just purchased a Rigid angle grinder and the salesman at HD helped me find an appropriate cut off wheel. Reading the instructions it cautions me not to use cut off wheels. The Internet search brought up discussions about too high rpms for some cut off wheels. the Norton wheel I purchased has rpm max at 13,500. Is it OK to use this wheel?
cut off discs with angle grinder
Re: cut off discs with angle grinder
both the 4 1/2 Ridgid grinders seem to rated at 10,000
http://www.ridgid.com/Tools/R1005-An...r/EN/index.htm
http://www.ridgid.com/Tools/Heavy-Du...r/EN/index.htm
I do not see a problem,
use a guard, and wear eye protection and gloves, doesn't hurt to keep your welding leathers on as well, (they will keep you from catching you clothes on fire from the grinding sparks..
I would be more concerned about pinching one and damaging it and then continue to use it when damaged,Push sticks/blocks Save Fingers
I seem to recall a few months ago, that this subject came up. I think the caution issued against using cut-off wheels on this angle grinder had something to do with that particular guard not being "OSHA" certified for use with cut-off wheels.
I'm still not clear as to the problem or exactly what the answer was.
I happen to have a Ryobi angle grinder and I do not recall seeing such a warning on it. That grinder is about four years old, but I believe is quite similar to the current model.... so I don't know if there is a warning statement in the current model's manual.
Does anyone have any updated information regarding the problem/use of cutoff wheels on the Ridgid model that may expand on the manual's statement?
The following is a quote from ProBrand on a similar topic:
“The RIDGID R1001 Angle Grinder has an included type 27 guard and is certified to Underwriters Laboratories (U.L.) product safety standards. U.L. requires only type 27 depressed center grinding wheels be used with type 27 guards. Type 1 straight or cut-off wheels have no depressed center posing a safety concern to the operator when connected to a type 27 guard. In no circumstance should a type 1 straight cut-off wheel be used with a type 27 guard. Please contact RIDGID customer for further assistance: 866-539-1710.”
Credit to ReConx for posting this.
Here is his post only larger so it's easier to read.
You need a different backing washer for cut off wheels. DeWalt sells them. The disks will bow and break without them, it will grip the metal hub, it is a smaller diameter washer/mounting flange. HD ,Lowe's have them. The OSHA stuff , well if you need to meet that for a job site but give me a break, we have used cut off wheels for how many years with the standard guards and now they are dangerous without a "special guard". Right. Be sure to wear eye and hand protection as any disk or wheel could break apart and the guard will never be totally safe anyway.
