Model RD80701 Power Washer - Pump Lubrication Question
  • Model RD80701 Power Washer - Pump Lubrication Question
    I just picked up an RD80701 3000 PSI power washer with a Cat 3GXT27 pump. The Cat pump came with a packaging tag that said to check lubricant level before each use and change after every 50 hours of use. However, unless I missed it, I couldn't find anywhere in the manual that indicated what the lubricant level is suppose to be, or what type of lubricant I am to use.
    Can anyway advise on this? Your help is appreciated.
    Re: Model RD80701 Power Washer - Pump Lubrication Question
    10W30 synthetic, halfway up the sight glass. And be SURE to remove the little black shipping plug from the red oil fill cap.
      Thank you!
      I ran the sprayer for 3-4 minutes before removing the packaging vent plug (initial engine start up - mainly it was just the engine idling, but I used pump for 20-30 seconds to test it out). Any cause for concern?
      Thanks again.
        No cause for alarm if that's all it ran.
        I work on two or three a week where the plug has been left in the cap. Sometimes it just causes a little oil to blow by the pump shaft seal without causing damage. But other times it blows the seal completely out and ruins the pump.
