9 hp wheelbarrow comp. problems
  • 9 hp wheelbarrow comp. problems
    Does anyone know how to remove the flywheel on my compressor ?
    Re: 9 hp wheelbarrow comp. problems
    If it is similar in design as my 5.5hp, then there should be a bolt on the flywheel that tightens up against a "keyway". Loosen the bolt, grab the keyway pin with vicegrips and pull towards yourself. You may have to tap the pin from the back. Once the pin is out of the shaft you should be able to take the flywheel off.
