Plexiglass Cutting Solution : JobMax !
  • Plexiglass Cutting Solution : JobMax !
    I looked for a long time for an easy way to cut finely
    small pieces of plexiglass .
    I bought a Jobmax oscillating tool .....geezz it is now easy ,
    with the metal blade , it cuts through without loosing the piece
    from my fingers ans it does a sharp cut .
    With the right movement/speed no heat , no melt ...
    and no power cord to be annoyed with .
    Glad I made the move
    Re: Plexiglass Cutting Solution : JobMax !
    Thanks ELOi
    I had to cut some Lexan and saw your posting.
    I have the $35.00 Harbor freight version of the "multi-tool"
    I attached the half round saw blade, secured the Lexan,
    attached a straight edge and went for it!
    It took about 4 minimal pressure passes.
    I was truly pleased with the results. I had minimal debris, no melting, a smooth cut that required a quick swipe with some 100 grit sandpaper and ..FINISHED!!!!
    This certainly much better than using a jig saw or table saw!
    Cactus Man
      Originally posted by cactusman View Post
      Thanks ELOi
      Cactus Man
      Thanks Cactus Man , I am pleased you had the same result .
      It is just incredible the power of sharing !!
      I am still looking to obtain this high gloss finish there is
      on the edge a "fresh" sheet of plexi ...even high polish
      with the finest grit dont achieve this result ....any clue ?
        I recall by using a flame and quickly passing over the edge causes the
        material smooth out nicely...be careful as too much heat will cause burn marks or torch the material
        This requires a light touch so practice on some scrap
        Cactus Man
          A bench grinder with a buffing wheel and jewelers rouge, also known as red rouge, will bring out a glass like finish. Get it as smooth as you can with fine sandpaper and then try the grinding wheel. It takes quite a bit of pressure on the wheel so a wimpy, low hp grinder will struggle but it will get the job done.
          When seconds count, the police are only minutes away.
            Thanks ...it works , as ex-jeweler I still have some rouge and
            a mini polisher wheel for my dremel ...now it is crystal clear
            Thanks
