TS3650 Table Saw problem
  • TS3650 Table Saw problem
    The bevel handwheel is bound up and won't move. I loosened the nuts on the handwheel after making sure the blade and bevel lock lever were unlocked The spring and nut on the lock lever are loose enough to turn with your finger. Nothing seems to unbind it.
    Help please.
    Last edited by CowCreekCarole; 08-29-2010, 09:16 PM. Reason: to add the last sentence
    Re: TS3650 Table Saw problem
    Take a look under the hood and make sure the zinc trunnion brackets aren't gauled.
      Yes, there is periodic maintenance required as hewood pointed out. Another place to check is that the screw threads are clean.
      Also clean the groove in the trunion brackets are clear, especially at the ends where it gets packed in. This can prevent you from tilting to a full 90 or 45 deg.
