Problem with 18V X2 "T" Handle Hammer Drill
  • Problem with 18V X2 "T" Handle Hammer Drill
    Hello, I hope someone can help me with this problem. I use this Hammer Drill a lot, and right now i can not remove a drill bit that i'm unable to release from the keyless chuck, is jammed.
    Re: Problem with 18V X2 "T" Handle Hammer Drill
    If the chuck itself is jammed it will probably have to be cut off and a new one installed. If you can loosen the chuck and just not get the bit out more than likely your bit has mushroomed at the base. Another possiiblitly is that the set screw is not installed and your bit has jammed itself into the hole where the set screw should have been. Unfortunatlely if brute force can't get it out the chuck would have to be cut off and replaced as well.
