Delta Planer
  • Delta Planer
    When I run boards through my planer they come out wavy any ideas what I need to do to fix.
    Re: Delta Planer
    By wavy I'm assuming you mean high and low points. The first thing I would check is to make sure your knives don't need replacing/sharpening. Also, do you have infeed/outfeed tables? If so, check to ensure that are level with the planers table.
    ------- Henry Ford
      Re: Delta Planer
      I do have in-feed and out-feed tables but the wavy (uneveness) is across the board in relation to the planer. Front to back is OK but I will have 1/16 higher or lower as you go across the board, if that makes sense.
        Re: Delta Planer
        If I'm understanding you correctly it sounds like you have some sort of problem with the cutter head height setting mechanism. Sounds like as the board passes through the planer the cutter head is moving downward. I don't own a Delta so I'm not that familiar with them. What model number do you have? Hopefully someone here will have the model you're talking about and can help you out better than I can.
        ------- Henry Ford
