Rigid Planner Cuts Off
  • Rigid Planner Cuts Off
    My Ridgid planner has been great, but recently every few minutes it turns off -- more quickly the more material is being feed -- and then kicks back on in about twenty seconds. What would be the source of this problem? Thanks, George
    Re: Rigid Planner Cuts Off
    planner cuts out
      Sounds like a thermal overload protector is tripping. What model and how old is it?
        How long of an extension cord are you using?
        Cactus Man
          I am not using an extension cord.
            The model is TP 1300 and it is about five years old. It has had moderate use.
              Check the motor brushes for wear
                I've checking the brushes and they seem fine. Any other suggestions?
