TS2424 Arbor Replacement
  • TS2424 Arbor Replacement
    I have a TS 2424 (circa 2000), and have severely dinged the threads on the arbor. Is there a way to replace only the arbor, and if so, how do I remove it from the rocker casting in which it is mounted. I notice that the parts diagram list the entire assembly and not just the arbor. Any help is greatly appreciated.
    Denis
    Re: TS2424 Arbor Replacement
    The Arbor is replaceable part number 508511. There is a retaining ring that holds the mount at the pivot point you will probably have to disassemble the adjuster screws also.
