Where to buy JobMax Universal Adaptor
  • Where to buy JobMax Universal Adaptor
    I have lost the universal adaptor for the JobMax Multi Tool. This is the adaptor that allows you to use accessories from Dremo or Bosch etc. Does anyone know where I can find this? Thanks in adavance.
    Re: Where to buy JobMax Universal Adaptor
    I don't have my parts list handy (the "Repair Sheet"), but that would be the first place I'd look. It should be in the normal "parts" area of this website, check under "Support" from the main page.
    You could of course also call Ridgid Customer Support.
    But, be prepared as I'm fairly sure that the shipping cost will probably far exceed the cost of the adapter itself!
    (I took my "adapter" and stuck it in one of the small "zip lock-typ" plastic bags that came with the kit, and I keep that in the pocket of the zipper case... the little thing is too easy to loose, otherwise.)
      The part is listed here....
      https://www.gardnerinc.com/recons/disclaimer-ridgid.php
      But is out of stock.
      Its also listed here...
      http://www.ereplacementparts.com/ada...-p-673461.html
        Does the JobMax adaptor look like this one from Dremel?
        http://www.amazon.com/gp/product/B00...ef=oss_product
          It looks similar, but the ridgid one allows you to flip it over and use it with Bosch accessories too. That apdator would work but only allow you to use the dremel accessories.
