LI battery / charger mismatch?
  • LI battery / charger mismatch?
    I'm the originator of the 'LI batteries and NO customer service' thread:
    http://www.ridgidforum.com/forum/showthread.php?t=34804
    While investigating my options, I came across the same batteries being sold by amazon.com. It says:
    "Ridgid 18 Volt Lithium Ion Battery 130383001 - Use only with Ridgid R840091 Battery Charger"
    That is my same battery number, but that is NOT my charger model. My charger is model #140276006.
    They came together as a kit, so one would assume they should work together but does anyone know for sure? Could a mismatch between charger and battery be the cause of both my batteries' demise? They were only charged maybe three or four times in their short lives.
    Kevin
    Re: LI battery / charger mismatch?
    Those two numbers are for the same charger. See here:
    https://www.gardnerinc.com/manuals/p...91_205_ENG.pdf
      Oh, okay, thanks. So much for that theory.
