Renew 2" Crane Gate Valve
  • Renew 2" Crane Gate Valve
    Hi,
    I have to renew or replace many (20 to 30) 2" to 4" Crane Gate Valve I want to know if their is some tool to renew the angle seat for this type of valve ?
    If I have to replace all valves it's a mess because they have some isolation neoprene and aluminium cover on it.
    Thanks
    Daniel
    Re: Renew 2" Crane Gate Valve
    i would think a mild acid/ lime away and a die grinder/ dremel will clean up the tapered seat that the gate closes upon.
    i think the bigger challenge will be to remove the valve bonnets without damaging the valve bodies.
    are the valves used for domestic potable water or are they for process piping
    where are you located
      Rick the first thing that i thought of was is he going to get them apart
      i never had luck doing it but it was on mostly heat lines
        What figure number (catalog or model number), pressure class (125, 250, 300), bonnet style(union, flanged, etc), and what is the body material?
        Most 2" and under gate valves do not have replaceable seats, and to lap the seat or grind a new seat would change the dimensions face to face and the existing or a new gate would not seal properly. Most times it is more cost effective to replace in kind. If the gate is screwed in line then you will have some extra work if no allowance was made during construction for maintenance of this type. That's the first place a designer or client looks to shave cost on a project. They save same money today at the expense of higher maintenance costs and increased downtime in the future. Good value engineering principles were not applied or ignored.
