How To Post Images
See more
See less
R4510 Table Saw Stack Dado Maximum
  • R4510 Table Saw Stack Dado Maximum
    The owners manual states this saw will accept up to a 3/4" stack dado. When I mount a 3/4" stack dado the arbor will not go through the arbor washer and nut completely. I can thread the nut on partly and appears to be secure, but not sure if this is safe. Is the manual wrong in stating this will accept a maximum 3/4" stack dado. I could exclude the arbor washer and then would be able to thread the nut so it extends through the nut completely, but not sure if this is safe either.
    For now I will reduce the dado thickness and run several passes to get the dado width I need.
    Looking for any insight on this. Thanks.
    Re: R4510 Table Saw Stack Dado Maximum
    skip the arbor washer. it's not needed for the stack dado. adequate arbor nut threading is more important.
      What Finer said.
