Dual Port Charger Mod #140276002
  • Dual Port Charger Mod #140276002
    Hello, I just recently purchased a used Dual Port Battery Charger off Ebay and it seems to work fine but after a few minutes it seems to intermittantly shut off and on. Does this mean the battery is reaching full charge? The owners manual does'nt say anything about this. Can anyone relate? Thanks
    Re: Dual Port Charger Mod #140276002
    what do you mean by it seems "to intermittantly shut off and on" ?
      The Green lts will come on along with the fan when charging and about 2 min's later it will shut off and then come right back on again. It only shuts down for a second then comes back on again over and over
        Could this be the reason the person sold it to begin with?
        How long have you had it since you completed the transaction on eBay.
        Get your money back if it is not as was represented in the item description.
        Did they claim it worked and was fully operational or did they just try the old "I don't know anything about this item but it does power up when you plug it in" story.
        Is it supposed to be NIB (New In Box) or NOS (New Old Stock) or was it "gently used" or "like new" (but really not).
          neither of the two units in my family do anything like that. i'd follow bob d's advice,
            That was how mine performed when I tried to use it to charge LI batts. As long as I only charge NiCad batts on it, it works fine.
