cordless impact driver Ah rating
  • cordless impact driver Ah rating
    Hallo
    I am about to invest in cordless impact driver on 18v system, I shop around (RIDGID, Makita, Hitachi, DeWalt etc..), then I notes that not all 18v system are the same theres 3.0 Ah and 1.5 Ah on the battery system, What are the difference.
    I will use my impact driver in tight spaces to extract bolt, I do some woodwork, but mainly automotive
    Sorry if I am in wrong forum or in wrong section.
    thank you
    Re: cordless impact driver Ah rating
    You're obviously only looking at Makita if you're mentioning this...
    3.0 / 2 = 1.5
    The smaller batteries don't last as long...
      IMHO, if you're doing automotive, try like hell to find a kit with NiCad batteries. They don't last as long (both service life AND runtime), but lithium batteries aren't the best idea for high load use. If you can't find a NiCad set, opt for the highest Ah lithiums you can get.
        Since when do you use an impact driver for automotive work?
          The cordless impact drivers won't loosen a lug but I have used them for removing small rusted nuts/bolts.
            Originally posted by ws6316 View Post
            Hallo
            The higher Ah batteries will have more endurance. The lighter 1.5 Ah batteries can be useful for overhead work.
              Go to your local shop and ask for yourself. Impact wrenches (but usually pneumatic) have been used in automotive service for decades. Milwaukee has had 18V & 28V 1/2 inch impacts for several years (which WILL remove/install lug nuts), and the smaller 3/8 and 1/4 have become very popular with mechanics as well. Any professional mechanic will have a few. I have almost a dozen in various configurations and use them daily.
                I guess I should have made it obvious and bolded DRIVER for you.
                An impact driver, and impact WRENCH, are NOT the same thing!
                Do you own any impact sockets with a 1/4" hex shank?
                Also, you're not getting anywhere near my vehicles if you install and torque lug nuts with an impact wrench...
                  Aside from the retainer, yes, they are.
                  Actually, yes. An inch set, 1/4 to 1/2 and a metric set 7mm to 13mm
                  Didn't offer to.
