18 Volt Impact Driver Problem
  • 18 Volt Impact Driver Problem
    I have a reconditioned 1/4" 18 volt impact driver model r842301 that stops working when the impact starts. I can pull the driver away from the screw, pull the trigger the driver works. I try to screw in the screw again and the driver quits working again. I can repeat running the driver with no pressure but as soon as the impact starts it quits. Any help?
    Re: 18 Volt Impact Driver Problem
    Try a fresh battery.
    If it still fails you now know that refurbished does not always means reliable
    Cactus Man
