9 Gallon Wheelbarrow Air Compressor problem!
  • 9 Gallon Wheelbarrow Air Compressor problem!
    Anyone have any solutions to my problem?
    when the compressor is running and the pump engages itself the compressor begins to... squeal like a dog in pain and then the engine struggles to run, it still builds air but seems to be getting worse... can't really describe it any better than that, any suggestions would be helpful. thanks
    Re: 9 Gallon Wheelbarrow Air Compressor problem!
    Belt tension checked & adjusted per the manual's instructions?
    EDIT: Never mind. Saw in the other forum thread that you've resolved your issue.
    Last edited by Doctordeere; 03-15-2011, 07:53 PM. Reason: Didn't want to look like a dumbass.
