Bandsaw Zero Clearance Insert
  • Bandsaw Zero Clearance Insert
    I have a BS1400 bandsaw. Does anyone have any experience with these zero clearance inserts and their fit on this saw?
    http://www.amazon.com/Insert-Imports...2143565&sr=8-4
    http://www.amazon.com/Bandsaw-Insert...2143565&sr=8-9
    http://www.rockler.com/product.cfm?p...ndsaw%20insert
    Re: Bandsaw Zero Clearance Insert
    I have the Rockler inserts on a 14" Jet BS and they are OK. It is tough to cut the initial slot so the insert fits properly and since a bandsaw blade tends to flex the blade slot distorts and get wider, negating the ZC benefit. A ZC insert works great on a tablesaw, but on a bandsaw they are of limited value. I wouldn't buy them again.
      Yeah you make a good point. I need a replacement hence the thought process of buying a few for zero clearance. I'll just scoop up a stock replacement.
