ridgid 3000 power washer
  • ridgid 3000 power washer
    I have a powerwasher that has all hoses connected correctly!
    But when engine is running, no water comes out nossel! And after it runs for a littlw while, hot water comes out relief valve! Any suggestions? Thanks, Greg
    Re: ridgid 3000 power washer
    Assuming that you've checked for a clogged nozzle, have a look at the following link. Remove, check & clean items 37 thru 41, and ckeck up into the pump body behind # 37... it sounds like your pump's clogged by scale/corrosion.
    http://www.arnorthamerica.com/rmpumps/rmv3400bd.html
