Howdy all,
Found this forum after looking for info on a TS3650 that I was looking at. I bought the saw today from a neighbor and it was in pretty good shape. The table needed some TLC it had some surface rust which I removed pretty easily then polished the top and waxed it so it is like new again. I have a couple of questions. This particular saw did not come equipped with the Herculift and as you may know this saw weighs a ton. I need to be able to move it around the garage and without any mobility it is going to be a little difficult to do that. Is the Herculift worth purchasing from Rigid or should i look into buying something after market?
The second thing I noticed was that the measuring scale on the fence rail is pretty useless. I am not sure if it is poorly designed or if it was installed improperly by the original owner but it isn't even close to being accurate like being 6"+ off. Should I purchase a new measuring scale as well to replace the one that was never installed properly or should i just use the tried and true measure from the fence to the blade procedure and not worry about it? I would like to be able to use the scale and have it be accurate but this would be the first saw i have ever had that had a useable measuring scale. My buddie has a Powermatic 66 cabinet saw and he uses the measuring scale on his saw exclusively and it is pretty convenient. His is so accurate that he just has to nudge it to adjust for tiny differences. Thanks again for any/all replys I am a pretty happy camper with my new to me TS3650.
