" field repairable " Quick Connect NPT fittings for 1/4 polyurethane
  • " field repairable " Quick Connect NPT fittings for 1/4 polyurethane
    I noticed the 25ft 1/4 inch polyurethane hose included with the air station compressor has a different style of fitting. It looks to be an all-in-one fitting with a barb & compression nut. Slip the nut on, slide tubing over barb, tighten with two wrenches, done.
    Does anybody know where these new fittings could be purchased?
    Haven't found them local or online. As parts, all I see is the tradiontal stuff with threads for factory ends and then some splice kits where you put a barbed end in with a clamp, then thread a regular fitting on.
    I've seen one Amflo branded hose list it as a feature as a field repairable fitting ( HD Model # 16-50E Internet # 202205321 Store SKU # 336728 ) but that looks to be like a two part one, plus in the picture it is hidden under a black spiral.
