Using Harbor Freight attachments with JobMax
  • Using Harbor Freight attachments with JobMax
    Harbor Freight's multi-tool attachments are very inexpensive, and with many of them the quality is acceptable. I had a tool box full of them when I bought my JobMax, and found that adapting those attachments to work with the JobMax was a fairly simple process.
    Using a 7/64 drill bit, I enlarged 4 of the pin holes in each attachment - the holes located at 12:00, 3:00, 6:00, and 9:00. The attachments would then fit the Bosch side of the JobMax adapter (included with the JobMax). I've been using the attachments for months without complications, and at about 3 bucks each, they're quite a deal. The little diamond blade is an especially good bargain. Big Lot's attachments will also fit the JobMax, using the above process.
    Dan
