Power Washer and Plastic Chairs
  • Power Washer and Plastic Chairs
    Just wanted to post a quick and easy way to clean those plastic lawn chairs and make them look new. Add about half a gallon of bleach and half a gallon of warm water to a pump sprayer and spray down the chairs making sure to get all the surface front and back. I let them sit for about five minutes then rinse them off with my pressure washer. Be careful not to get too close with a strong nozzle to prevent scarring the plastic. This method should easily and quickly remove dirt, grime and mildew.
    Re: Power Washer and Plastic Chairs
    how do you keep the chairs from being chased down the drive way, if I would hit a plastic chair with my washer it would move very easly, and I do not have a super washer like Ricks, ,
      I have my chairs on a deck so I prop them up agaist the ballisters, then turn them around and place them at an angle against the rails. If I was going to do this on the driveway, I would lie them on their backs and try to get directly over them. You could turn them face down and put a foot on the end of one of the legs to hold them in place. I agree the power washer blows them around like a kite if they are not supported against something. I have a Karcher gasoline pressure washer and using the green nozzle works best.
        Or, you could just ask your MIL to sit in them.
        Diapers and Politicians need to be changed often... Usually for the same reason.
          Wouldn't fit
