Power Washer and Plastic Chairs
  • Power Washer and Plastic Chairs
    Just wanted to post a quick and easy way to clean those plastic lawn chairs and make them look new. Add about half a gallon of bleach and half a gallon of warm water to a pump sprayer and spray down the chairs making sure to get all the surface front and back. I let them sit for about five minutes then rinse them off with my pressure washer. Be careful not to get too close with a strong nozzle to prevent scarring the plastic. This method should easily and quickly remove dirt, grime and mildew.
    Re: Power Washer and Plastic Chairs
    how do you keep the chairs from being chased down the drive way, if I would hit a plastic chair with my washer it would move very easly, and I do not have a super washer like Ricks, ,
      I have my chairs on a deck so I prop them up agaist the ballisters, then turn them around and place them at an angle against the rails. If I was going to do this on the driveway, I would lie them on their backs and try to get directly over them. You could turn them face down and put a foot on the end of one of the legs to hold them in place. I agree the power washer blows them around like a kite if they are not supported against something. I have a Karcher gasoline pressure washer and using the green nozzle works best.
        Or, you could just ask your MIL to sit in them.
          Wouldn't fit
