Ridgid 3000 Power washer no water
  • Ridgid 3000 Power washer no water
    I have connected hose turned on water and have no output whatsoever any ideas?
    Re: Ridgid 3000 Power washer no water
    Model number please?
    Let's assume it's the 80746 since that's the one most likely to have this issue.
    Let's also assume you've already made good & sure that you don't have a clogged nozzle.
    Check this discussion and try the suggestions offered...
    http://www.ridgidforum.com/forum/t34161/
      Sorry model is rd80746 with rmv 2.3g30 pump
        Ok I checked assembly behind high pressure outlet and replaced an o ring other than that looked fine.
        Unloader was stuck but I got it moving again now when I hooked up the water it flowed out the wand continuously but when I tried to start it water shut off and now I can't pull the rope very hard(pump has too much pressure?)
        UPDATE: Ok I got motor started water comes out outlet but motor stalls without much output pressure.
          Issue is SOLVED!!!! I took another look at that unloader valve and realized I didn't take it all the way apart and sure enough their was a broken o-ring inside! Thx for the helpful forum and your collective wealth of knowledge!!
            Good job!
            Feels good, doesn't it?
