Something new (unloader valve)
  • Something new (unloader valve)
    I also have a rd80746 that lost an o-ring. it was the top one and I am not sure I put it in the right spot. Also (might be because of valve) motor bogs when I pull trigger and goes to a high rpm when I let off. (high rpm being normal rpm)
    Re: Something new (unloader valve)
    Since I got no replies I removed top o-ring and reinstalled it. It runs ok now but will that hurt anything?
      I have no experience on the machine or this type of unloader,
      my guess is if it runs OK, and works OK I would not worry about it,
      (I looked and could not find any drawing or info on the unloader it self)
        As promised, a photo of an unloader stem from a properly working pump.
        • Rigidboy
          Rigidboy commented
          Editing a comment
          How do you get the uploader stem out of the casing that houses it?
        thx much this will be a big help ensuring I get it right!
          One thing I notice missing from your photo is the tiny fiber back-up ring (little brown flat fiber washer). Check and see if it's still in the unloader body or if it's been blown out.
            Thanks to Doctordeere I got my power washer back in good running order a while back (unloader valve sticking). I really appreciate his willingness to share years of expertise. Thank you sir!
