R5010 HD VSR Hammer Drill Chuck upgrade?
  • R5010 HD VSR Hammer Drill Chuck upgrade?
    I absolutely HATE the chuck on this hammer drill. Is there any after market chucks that would replace this? Is there a SDS chuck? If not, I don't care, just something other than this pile that came on the drill would be nice.
    The R5010 and R7100 both share the same output shaft so do you think it would be able to use the standard R7100's chuck? The R5010 chuck is over 100 bucks! The chuck for the R7100 is only 35 bucks!
    Any ideas?
    Re: R5010 HD VSR Hammer Drill Chuck upgrade?
    I believe the spindle shaft is 1/2X20 threads, so just about any chuck will work. If memory serves, the 5010 has a keyless chuck while the 7100 is a keyed chuck. I prefer keyed chucks anyway (as long as you don't lose the key), so I would consider it an upgrade.
    SDS is for rotary hammers, not hammer drills.
      IMO go with the keyed chuck on the hammer drill. Inexpensive low quality keyless chucks can loosen at the worst time
