Manual for Ridgid Power Washer Mod. RD80701
  • Manual for Ridgid Power Washer Mod. RD80701
    I just bought a Ridgid power washer 3000PSI, an older display model, none of the attachments or manual was there. I have found the motor and pump manuals but no manual for the complete power washer. What is the easiest way to get a manual, I am also missing the hanger for the wand, so I need a few parts as well.
    Thanks,
    James
    Re: Manual for Ridgid Power Washer Mod. RD80701
    You should be able to order the part you need from eReplacement Parts.
    This link should take you to the Owners Manual.
    Diapers and Politicians need to be changed often... Usually for the same reason.
      Dave:
      I tried there no manual available and I haven't found a home site for Ridgid?
        Dave:
        You are hooked up, that link was exactly what I needed.
        Thanks,
        James
          Parts list:
          https://www.gardnerinc.com/manuals/p...3_278_r_04.pdf
          Operator's manual:
          https://www.gardnerinc.com/manuals/p...TRILINGUAL.pdf
