no display on generator
  • no display on generator
    Last year I bought a Rigid 8000w generator with the Subaru motor. I've only used it a few times; however, I thought I'd warm her up due to the hurricane that's coming and I have no display (no digital display) and no power to the outlets. Any ideas out there as to what I can do?
    Thanks!
    Re: no display on generator
    First, remove the remote panel and make sure the round AC plug is plugged in correctly.
    If that's not the problem I strongly suggest you let your local ASC deal with it. If you attempt repair yourself you run a very real risk of voiding your warranty.
      Thanks for the quick response. I checked the panel and the ac is correctly plugged in..I've actually never removed the panel before. So it looks like i'm calling customer service. Thank you!!
