Charger in the R9651 package appears to be broken right out of the box
  • Charger in the R9651 package appears to be broken right out of the box
    I just purchased the Rigid 5 pc set from home depot and after unpacking everything I pluged in the charger and the power light comes on a solid green, so far so good. However, right after I plug a battery into the charger the "?" and battery charging light lights flashed and then all three lights (including the power light) go out. After a second the power and battery charging light come on for a second then the "?" light flashes and all the lights go out again. This process just keeps repeting its self for as long as the battery is in the charger.
    I assume that what i am seeing above is not normal can someone confirm that?
    Thanks
    Ben
    Re: Charger in the R9651 package appears to be broken right out of the box
    Return it for another kit
    Two possible problems..defective charger and/or bad batteries
    Don't mess with it simply take it back and exchange it for another set!
    Make sure the new set has the box sealed properly and not resealed..that
    means it has been opened and may be a returned unit
    Cactus Man
