Cordless Miter saw
  • Cordless Miter saw
    Im sure this is a mistake 15 Amp 12 in. Cordless Sliding Compound Miter Saw-MS1290LZ1 at The Home Depot
    Re: Cordless Miter saw
    I'd like to see the 15 amp battery that comes with it.
      You're correct, not cordless. Unless the one I have has some hidden abilities I haven't found.
        • They cant make up their minds... Taken from the specs.. Look in red.
        • Arbor Size : 1 In.
        • Assembled Depth (in.) : 39.49 in
        • Assembled Height (in.) : 21.46 in
        • Assembled Width (in.) : 26.02 in
        • Batteries Included : No
        • Battery Type : N/A
        • Battery charge time (min.) : 0
        • Bevel : Yes
        • Blade Diameter : 12 in
        • CSA Listed : No
        • Charger Included : No
        • Color Family : Orange
        • Cordless Tool Type : Miter Saw
        • Cordless/Corded : Corded
        • Depth (in) : 39.20 in
        • Dust Collection : Yes
        • ETL Listed : No
        • Height (in) : 21.10 in
        • Item Package Type : Cardboard Container
        • Item Weight : 69.66 lb
        • Keyless/keyed blade change : Keyed
        • Manufacturer Warranty : 3 Year Lifetime Service Agreement with tool registration
        • Maximum Cutting Thickness (in.) : 6
        • Maximum Degree Miter Cuts - Left : 61 °
        • Maximum Degree Miter Cuts - Right : 61 °
        • Power Tool Product Type : Cordless
        • Product Depth (in.) : 40.1 in
        • Product Height (in.) : 22 in
        • Product Weight (lb.) : 81.7
        • Product Width (in.) : 26.02 in
        • Reconditioned : No
        • Returnable : 90-Day
        • Switch Type : Trigger
        • UL Listed : 1-UL Listed
        • Voltage (volts) : 0 V
        • Width (in) : 25.90 in
          Specs say CORDED.
          A 12" 15 amp cordless? 40 pound tool, 120 pound battery?
            • Battery charge time (min) : 0
            • Bevel : Yes
            • CSA Listed : No
            • ETL Listed : No
            Green highlighted items might give further indication as to not being cordless, but you're right, they seemed to be confused as to what they're really trying to describe here.
