r4512 table saw problem
  • r4512 table saw problem
    I have had the table saw for about 1 1/2 years. I am not a daily user. It used to run and cut great. Now when I use it it starts vibrating and the blade starts stopping. Even on what used to be be simple easy cuts. I have tried two different new blades with no positive results. The belt still looks new.
    Any suggestions?
    Re: r4512 table saw problem
    Check for a loose pulley or out of alignment pulleys.
      Any help on this, I believe I have one or both of these problems. belt stalls after cutting through a dado ZCI. Tried tightrning the belt, but still stalls out.
      Manual is quite unclear, and does not mention loose pulley at all. My old craftsman everything was in the open and easily tightened
      thanks in advance
