Rigid 10" table saw TS2400
  • Rigid 10" table saw TS2400
    I have a 10" table saw that will not come up to speed when turned on. Any ideas on what to check before I shell out the $ for a new motor. Are there any certain parts that where out over time that could cause this?? Any insight would be appreciated.
    Re: Rigid 10" table saw TS2400
    Have you tried plugging the saw into a different circuit?
      yep thanks for the suggestion though
        is your 2400 a gray model ridgid? if yes, the defect might be covered by the tools lifetime guaranty. i'd contact ridgid CS and see if they authorize a free repair. better they spend than you. the worst they can say is no.
          That saw uses brushes in the universal motor...check them for wear.
            Did this problem ever get resolved?
