Ts 3650 Dust Collection on the Cheap Side
  • Ts 3650 Dust Collection on the Cheap Side
    just wanted to post some pics for simple dust collection for TS 3650, its attachedClick image for larger version
ID:	635180 to PSI 2 hp dust collector with 4" hose. "y" connection at bottom of saw 2 1/2" hose up to blade guard and adapted to 1 1/4" hose at the guard itselClick image for larger version
ID:	635179f. Just have to squish the smaller hose at the guard to fit in the slot and it works pretty well. On the bottom 2 1/2 inch hose at factory dust colleClick image for larger version
ID:	635178ction port fitted to 4" - 2 1/2" adapter got from peachtree, its the tapered one for better flow. Its not perfect but it works and helps hold down thClick image for larger version
ID:	635177e dust, when I use the dado blade I just put the 2 1/2" hose at front of table to catch whats coming off the blade. Now go make some sawdust.
    steve Click image for larger version
    ps: note broken yellow expensive magnetic feather board, my reminder to never reset feather board near spinning dado blade, parts will fly!!!!!
    This has been a great saw, had it 4 yrs bought from Woodworking show at Indy and was factory refurb got for around $300.00 I believe
    Re: Ts 3650 Dust Collection on the Cheap Side
    I have seen a few variations of the set up you have created. Some others cut parts of the guard away to improve the airflow/collection. I'll see if I can find the link.
      Here is a link to a modified 3650 blade guard. Dust collection for contractor table saw. - by bsherman @ LumberJocks.com ~ woodworking community
