10" Portable Table Saw R4516 Problem
  • FINER9998
    Re: 10" Portable Table Saw R4516 Problem
    Originally posted by Frankiarmz View Post
    I copied the following from page 38 of the PDF file, are you saying that on the printed owner's manual it does not mention the reset circuit breaker button or fuse?TROUBLESHOOTING
    Problem
    Cause
    Solution
    Adjust positive stops.
    Adjust the miter gauge.
    Clean the gears or screw post.
    Plug in motor cord or wall cord.
    Replace circuit fuse.
    Reset circuit breaker.
    Have the cord or switch replaced at your
    Sears Service Center.
    Clean, sharpen, or replace blade.
    Replace with correct type.
    Remount blade.
    Move locking lever to left.
    See cleaning instructions in the Maintenance section.
    Change blade; rip blade typically has fewer teeth.
    Saw does not make accurate 90˚ or 45˚ cuts.
    Height/bevel adjusting hand-wheel is hard to turn.
    Saw does not start.
    Blade makes poor cuts.
    Blade does not lower when turning height/bevel adjusting handwheel.
    Motor labors in rip cut.
    Positive stops inside cabinet need adjusting (Bevel Cuts).
    Miter gauge is misaligned (Miter Cuts).
    Gears or screw post inside
    cabinet are clogged with saw
    dust.
    Motor cord or wall cord is not plugged in.
    Circuit fuse is blown.
    Circuit breaker is tripped.
    Cord or switch is damaged.
    see above for what i was referring to. the OP was referring to a ridgid product, right?
  • Frankiarmz
    Problem
    Cause
    Solution
    Remount blade.
    Saw does not start.
    dust.
  • FINER9998
    someone somewhere hasn't proofread the referenced OM . in the troubleshooting section of the referenced owners manual, for "saw does not start", if the problem is "Cord or switch is damaged", the Solution is "Have the cord or switch replaced at your Sears Service Center." (see page 38).
  • Frankiarmz
    Found the owner's manual for your saw, PDF file, circuit breaker reset and fuse mentioned so it's there!
    http://www.ridgid.com/ASSETS/920B1F2...16_415_eng.pdf
  • Frankiarmz
    I found this link and it discusses a fuse and circuit breaker. How to Troubleshoot a Ridgid 10 Portable Table Saw | eHow.com
    I think there has to be a fuse or circuit reset button of some kind, just don't know where. Please learn from this unfortunate event and don't lend your tools out! There will probably be a somple fix for your table saw and you are better off with this person out of your life. If he could not be bothered to man up and have the saw looked at, he is not worth your time and effort. Good luck. Frank
    Check this out! They talked about the reset being inline before the motor.
    have a Rigid TS2400 (table saw).......all of a sudden it won't run. I've checked reset and outlet....okay.
    Is there an easy spot to see if switch is bad???? Or is there a spot on motor.....to see if power is getting to it?????
    I have a volt meter........but just looking for the best choice(s).
    Thanks.........D
    ReplyReply Reply: Electric Problem
    Mike
    It's most likely a bad on/off switch, but sometimes those reset switches will go out too. These are some of the most common repairs we see for the TS2400 saws. With an Ohmmeter you can check both switches, and I think you can check the leads with your voltmeter. Here are links to the switches:
    on/off switch:
    eReplacementparts.com : Locking Switch [826347] - $7.87
    Reset switch:
    eReplacementparts.com : Reset Switch [829971-6] - $9.55
  • FINER9998
    no good deed ever goes unpunished.
  • BadgerDave
    If you registered your saw into the Limited Lifetime Service Agreement when you purchased it a year ago, just take it to a Ridgid Service Center and they will fix it for free. You will need to supply them with you Member Number for the LLSA which you'll find on the card Ridgid mailed you after you registered the saw. It's nice of you to lend out your tools but it's circumstances like this one that cause many people to never lend out their tools.
  • wendyth2
    Thank you for the reply. I have checked the cords and they're fine. It has to be internal in the on/off switch or motor.
    I did phone the guy who borrowed it and his reply was "It worked when I used it ... I don't know what you could have done".
    He's not answering my phone calls or my text. It upsets me bc he's not taking responsibility for it.
    I still have not found a reset button. The saw is just over a year old ... You would think there'd be one some where on it.
    Wendy
  • BadgerDave
    Check the wire connections at the switch and also where the power cord connects to the motor. Better yet, have the person you lent it to take it to an authorized service center and pay to get it running like it did when they borrowed it.
  • wendyth2
    started a topic 10" Portable Table Saw R4516 Problem
    Hi
    I have a Ridgid 10" portable saw I lent out. I went to use it now and it doesn't start.
    Is there a reset button on the saw somewhere? I can't see one to save my sole and the manual doesn't indicate there is one.
    If someone knows if this saw has one and can tell me exactly where to find it I'd appreciate it.
    Thanks
    Wendy
